М18А на Джимни. Австралийский опыт.
  • Автор темы Zook
  • Отслеживают тему 12
Zook
Модератор
414
Москва-Сокольники
Hi guys,
Want to intro myself and my Zook,
Currently live in Goulburn, NSW work as an antenna Tech
Have had the car about 6 months now, bought as a stocker 2001 model i have since fitted-
50mm body lift
235/75 15 bighorns on king rims
Full rear draw set
M18a vvt engine conversion (from 2005 liana)
Full S/S exhaust
ARB towbar
ARB bull bar
Has been a great project so far, particularly learning just how smart Suzuki was when building their engines!
Currently am using the car for work but will sadly be selling in a few months as i feel i will eventually ruin it using it for work (Rather get a rodeo or lux that i don't care so much about....anyway,
Enjoy some pic's
The engine conversion is very easy, just have to find an engine with reasonably low K's (20,000 for mine, LUCKY!!)
put both engines together on a bench and swap everything over!!
Engine mounts, sump, alternator, gearbox, water pump, water outlets, main pulley, Exhaust manifold etc SWAP STRAIGHT OVER!
If your jimny is pre vvt then things get a bit messy with wiring but if you have a vvt jimny you can plug your loom straight in and just change computer/pinouts and imobilizer!
I don't think a non vvt ecu will run a vvt motor!
I have pinout diagrams for the 2001 jimny and the liana and they are different, meaning if you plug the ecu into the loom unchanged the pins will not match up with wires on the loom.
I also can say that a 2004 jimny pinout is different from a 2001 model jimny because i have both here!
If i was to do the transplant again on a non vvt jimny i would use the m16a from the pre vvt liana myself!
Engine mounts bolt straight onto the block! as far as i can tell suzuki have used the same block and head castings for ALL m series engines, some are just machined differently, so body lift is not necessary.
I used the jimny sump and pick up, the only problem here is you need to re-drill the dipstick hole in the rear of the head and then plug the front hole. it's not a problem though as suzuki in it's wisdom have made provision for this
The oil filter could be swaped to screw straight into the block as on m13a, but i like the angle adaptor that comes with the liana motor as it makes filter changes a bit easier (does limit filter size though)
I used the liana clutch as is an Exedy, had to machine the liana flywheel about 3mm to give more room for the throw out bearing! their is no reason you can't use the jimny flywheel and clutch though (might slip a bit)
At first it was for me, but i got the hang of it!
First you need this stuff(jimny and liana pinouts)...
then you grab your three ecu plugs and pull up the long flat tab at the back of each one...
than use a needle type tool to push into the front of each plug and remove the wire till you end up with...
Then you have to re-insert the wires to match up with what the liana ecu pinout list says they should be, and push the long tab down again...EASY
A few more pics with the new air box!
Got it from a ce lancer (needed a few mods )
Ссылка на оригинал http://auszookers.com/index.php?name=Forums&file=viewtopic&t=9779&postdays=0&postorder=asc&start=0
Реакции: 11 человек
Юрок
11 Март 2008
221
Ответ: М18А на Джимни. Австралийский опыт.
А какой там литраж/мощность?
Двигатель SUZUKI / СУЗУКИ M18A
Объём: 1.8 л.;
Тип питания: распределённый впрыск Модель двигателя (Engine Code): M18A, бензиновый (Gasoline)
Тип ГБЦ: DOHC
Количество цилиндров: 4
Объем двигателя, см3 (Displacement (cc)): 1796
Мощность двигателя, л.с/оборотов-мин (Power (bhp/rpm)): 125/5500
Крутящий момент, н-м/об.мин (Torque (ft/lbs@rpm)): 169.5/4200
Диаметр (Bore)/Ход поршня(Stroke), мм: 83.0/83.0
Степень сжатия (Compression Ratio): 9.60
japman
НЕИЗМЕННЫЙ SUZUKOфил
1 Декабрь 2008
3,886
2,077
Я так понимаю мотор с Аерио/лиана 4 везде!!!!!!заманчиво.........
EDI
27 Апрель 2006
6,806
2,229
Израиль
авто
1.8 только для Америки делают , редкий звэрь в России
о.... ёлы палы.... у жены Лиана
переставить что ли ?
или жить пока ?
japman
1 Декабрь 2008
3,886
2,077
или жить пока ?
EDI ты не прав--ещё япы для себя на сузуки аерио ставят!!!!!!!!!!!
Дивный
8 Февраль 2009
3,575
979
Jimny 2003 г.в.
Можно из Владика заказать ;)
Brian Bugster
13 Июль 2009
70
Москва, Ново-Переделкино
Suzuki Jimny Wide 1998 JB33W G13B
У меня сегодня мой G13 застучал, предвещая скорую кончину вкладышей... 208 т.км. Интересно, заместо моего влезет? :)
Zook
Модератор
414
Москва-Сокольники
Мозги разные, придется с косой своей ставить.
Brian Bugster
13 Июль 2009
70
Ну я вообще так, спортивного интересу ради спросил. Щас отпуск начнется - разберу все, посмотрю, если не успело все раздолбать (клина не было), то буду чинить, а если успело, то 1,6 покупать буду. Кстати, G16B я так понял нету, есть G16A 1,6 VVT, да? Не могу найти тему про замену 1,3 на 1,6 для точных данных...
suzukoff
27 Июнь 2009
884
383
Улан-Удэ
Zook
Модератор
414
Москва-Сокольники
G16 много разных модификаций - трамблерные, безтрамблерные, карбюраторный, инжекторные, 8 и 16 клапанные. В идеале нужно 16и-клапанный одновальный (не знаю, были ли двухвальные) безтрамблерный инжектор, но можно обойтись и трамблерным с установкой своего распредвала и клапанной крышки.
volodream
Джиппер-мотоциклист
30 Май 2007
580
152
Питер, пр. Большевиков
ЖымнеГ 2004 весь на механике, лебедка, защиты и трубы от Sprinter`а.
Для епосвященных объясните!
Что дает установка такого движка на джимни, кроме максимальной скорости и большего ресурса? (лучший момент на низах, разгон до сотни, меньший расход бензина или что?)
Zook
Модератор
414
Москва-Сокольники
Ну, ты ВСЕ пункты, вообщем, и перечислил! :)))
volodream
Джиппер-мотоциклист
30 Май 2007
580
152
Действительно ли меняется момент на низах?
Просто все остальное для джимника нафиг не нужно :) Хотя прикольно будет если джимник в обвесе на 33 бугерах будет обгонять спорткары на кольцевой:D
Дивный
8 Февраль 2009
3,575
979
Jimny 2003 г.в.
ну вот что ты занудничаешь? )))
на 1,5 прокатился? вот для 1,8 то, что почувствовал, только более выражено ;)
volodream
Джиппер-мотоциклист
30 Май 2007
580
152
Леш,так о том и речь, что у тебя низы почти не изменились (ну совсем почти не заметно), а все остальное хорошо конечно, но не главное :)
Не, просто могу сказать, что менять работающий 1.3 на 1.5-1.8 не вижу смысла, только если родной помрет (как у тебя), ну или совсем если делать нечего:D
Zook
Модератор
414
Москва-Сокольники
Думаю, что разница между 1,3 и 1,6/1,8 будет заметней. Если уж менять, то на них.
Вот сравнение характеристик (могут, наверное отличаться в разных источниках, но не принципиально):
М13 М15 М16 М18
Объем 1328 1490 1586 1796
Мощность, кВт/обороты 62,5/6000 75/5900 79/5600 125/5500
Момент, нМ/обороты 110/4100 133/4100 145/4000 169/4200
А вес?
Десять символов
Zook
Модератор
414
Москва-Сокольники
По поиску "двигатель Suzuki G13" выдаются одни авиационные сайты )))
Вот оттуда, похоже действительно разница не большая )
Вес четырехцилиндрового двигателя Suzuki G-13В в сборе с навесным оборудованием (патрубки жидкостного охлаждения, радиатор, электростартер, высоковольтная катушка, генератор мощностью 450 Вт, электропроводка, редуктор, кронштейны крепления двигателя, моторное масло, тосол, воздушный фильтр, глушитель) без воздушного винта – 83 кг
Продам силовую установку Suzuki G-16. На летательных аппаратах не эксплуатировалась. Произведена полная ревизия, все технические параметры в норме. Редуктор Чернова, новый- степень редукции 2,5. Установлен карбюратор ДААЗ-3302. Обкатан на стенде, статистическая тяга 235 кг. Вес силовой установки 89,5 кг.
Пишите в личку. Готов ответить на все вопросы.
Главное вовремя остановится, силовые с Suzuki M13 и Honda D16 имеют вес 120кг+
G13 - вес СУ в сборе без винта 95-105кг, мощности хватает. В наше время это наиболее популярный зверушка среди Сузуководов.
G16 - вес не менее 100кг (высота блока цилиндров на 25мм выше чем у G13), зато мощность от 107 до 120лс. Как правило, сей двыгун наиболее поздних годов выпуска, соответственно вероятность нарваться на изношенный движек меньше. На свой новый пепелац я поставил G16, уж больно разница в мощности чувствуется...
BK
12 Апрель 2010
70
Чита
Suzuki Jimny Wide 98 г Лифт 60 мм Бодик 50 мм Лебедь Winch 6000, Хабы AISIN Механические Бампера силовые в процессе изготовления!!
У меня 1.3 98 г . Млин народ мне эта тема все покоя не дает!!! Если я сильвера 31 поставлю и не ставя китовые шестерни в раздатку или Г/П от 066 а сразу воткну M18A он же нормально попрет по трассе енто понятно а в грязи интересно на низах нормально тянуть будет или как на раздатке и Г/П от 1.3, коробку вместе с двиглой от аеро ставить надо да?
И еще момент один мне не доконца понятен там на рис. взлахмоченые фишки от компа, они че косу м18 перебрали под фишку и комп джима 1,3 что ли??Чешу репу.
Kraftwagen
25 Июнь 2009
185
143
Москва ВАО
SJ413,TLCBJ75,LRDef90
Хорошо, покупаем и устанавливаем двигатель побольше, всё прекрасно. Кто регистрировал? Кто вносил изменения? Это не бампер - насколько затратно по времени?
BK
12 Апрель 2010
70
Чита
Ну впринципе вся ента херь занимает около 1 месяца не торопясь енто у нас в чите
1 Пишешь заяв в ГАИ на смену двигла они тебя отправл в НАМИ
2 Делаешь НАМИ приходишь в ГАИ
3Они тебя отправляют на СТО на переделку
После переделки На перерегистрацию осмотр машины и получаешь новую ПТС с новым в ней двиглом по деньгам ХЗ последний раз я енту операцию делал год назад и регил я целую машину на другую ПТС НАМИ в пределах 5 Тыс руб ну и госпошлины в Гаи за перерег!;)
Ну так кто нить мне ответи на мои вопросы или мне дальше репу чесать? Чешу репу.
MPV
7 Сентябрь 2007
1,085
169
Двигатель М15А
У тебя машина 98 год а это значит движка G13.
Хочешь мотор серии M, значит тебе понадобиться двигатель М18 с компом, двигатель М13 только от джимни с навесным. Менять двигатель просто если у тебя уже движка этой серии.
Даже если поменял, останется вопрос с раздаткой, долго ли вынесет и так слабая цепь при возросших нагрузках.
Kraftwagen
25 Июнь 2009
185
143
Москва ВАО
В теории понятно. Я спрашивал про реальную замену 1.3 на 1.6 или 1.8. Проблема в том, что двигатель другой, не предназначенный для использования на данном автомобиле. В ГИБДД могут тупо не принять завку. Понятно, что "другими" методами можно сделать всё. Мну интересуют реальные преценденты.
Дивный
8 Февраль 2009
3,575
979
Jimny 2003 г.в.
В Питере назвали цифру 25 000
мотор М15А
MPV
7 Сентябрь 2007
1,085
169
Двигатель М15А
1,6 смысла нет ставить. 1,5 тоже самое. К тому же 1,6 движки реже встречаются.
Свой пока не оформлял, пока времени нет.
M
mynicknamex
Следует понимать, что пока документов нет? или уже свершилось?
а перебить цифири на двигле можно, сделать по документам из нового двигуна тот что у тебя стоит и не регать его?
ваще что за беспредел на кой ... сделали регистрацию двигунов.
